Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
09-27-2023, 03:15 AM
Vans Rivet Removal Video
Just out - great tips at a steady, steady pace ;-)
https://www.youtube.com/watch?v=FpkmGbYOCOk&t=509s
I am presuming Scott has modified a pair of 8" side cutters by grinding them flush to be able to grip the shop head well. Normal side cutters have a double edge.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2023
09-27-2023, 09:37 AM
Yes
We shot B roll that was supposed to show a modified and unmodified tool side by side but I guess it accidentally got left out? (I don’t know because I haven’t watched the video)
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips, ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR & Pre-purchase inspection Services
A&P, EAA Technical Councelor
09-27-2023, 02:12 PM
As you replied on YouTube - Manual part 5 I think to modify the tool.
I got a pair of 8" side cutters, 5 mins on the belt sander with cooling, sorted.
Great video
Donated in 2023
09-27-2023, 02:53 PM
Rivet Cutter
There are flush rivet cutters available starting at under $10.
09-27-2023, 03:18 PM
Very appropriate video considering what is coming for allot of folks…..
Brantel (Brian Chesteen),
RV-12IS Empennage/Tail Cone Finished, Wings and Fuselage Kits In Progress, Finish kit on order!
Serial #121606, N912BC (reserved)
→ Check out my RV-12IS builder's BLOG
Check out my RV-10 builder's BLOG (Good stuff for those starting an RV-10)
RV-7/TU, #72823, N159SB Airplane Sold
09-27-2023, 05:16 PM
Summarized 5+ years of lessons learned the hard way in 30 minutes  Seriously, every small nuance I can think of was mentioned. As with all things airplane building, patience is just as important as the tools and technique.
I cringed every time I saw him brush the shavings away with his hand. I lost count of the number of times I cut my fingers open doing that when a drill shaving wasn't fully liberated.
I think Scott should consider a post retirement gig as an audio book artist.
Vintage Cherokee 160
RV-7:
Finish/FFW in work
09-27-2023, 05:21 PM
This! I keep a 2" paint brush on my bench to sweep off shavings, cheap and easy to replace when needed.
09-27-2023, 06:05 PM
Probably a bad habit, but I guarantee you my fingers would not have gone anywhere near the drill swarf if I was drilling anything other than aluminum.
After a lot of years doing this, I have never been injured by aluminum drill swarf.
Undeburred aluminum sheet edges is a totally different discussion... though it hasn't happened very many times....
Scott McDaniels
Hubbard, Oregon
09-28-2023, 02:09 AM
I found these to be quite handy.
Notice the notch in the jaws.
Webb Willmott
KJVW
RV8 - Current Build
N414WW Reserved
V35B - Flying
RV7A - N32WW (Sold)
09-28-2023, 07:18 AM
Great video.
It should go without saying but since it is a teaching/instructional video;
A mention about the importance of sharp drill bits, how they make staying on point easier, etc. early in the video would probably be appropriate.
The simplest things can make a job easier/lessen the risk of mistakes. Kinda have to assume the audience are true rank amateur sometimes.
Again, great video.
Side note/thread drift. Has anyone found a good source of cobalt bits? They may indeed last longer but I wouldn't know. Even new, they aren't sharp. All of mine are now sacrificial or home project bits.
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
