Need Flywheel Ring Gear IO360
I need to replace my flywheel ring gear because of a few chipped teeth. I have a Lyc IO360. I think I need the 149 tooth version. My thought is that I should change just the toothed ring so I might not mess up my dynamic balance.
Where would be the best place to find one? Can I get a new one or would it matter if I found a good used one. Is a place like Wentworth a good bet?
BB
