Old 10-02-2007, 01:07 PM
Mhead's Avatar
Mhead Mhead is offline
Default Rudder Stiffeners, to flute or not to flute?
I am finishing up the stiffeners for my -7 rudder and they are somewhat bowed similiar to the ribs in the stabilizers. I am tempted to flute them to make them sit flat on the skin. I searched the forums and only found a lot of discussion about oil canning, etc. Should I flute, or just back rivet them making sure they are pressed flat to the skin?
Gary Moore
Northwest Arkansas
Working on the firewall forward....
RV-7, N742GM (Reserved)
http://mykitlog.com/mhead
Donated 9/9/19
Old 10-02-2007, 01:37 PM
jsharkey's Avatar
jsharkey jsharkey is offline
Back rivet pressed flat to the skin. Fluting is generally only used to straighten any out of plane bow induced when you you bend a flange on a curved edge. The rudder siffeners are straight so any bow should be minimal after you rivet them down to the skin.
Old 10-02-2007, 02:27 PM
mgomez's Avatar
mgomez mgomez is offline
Default No fluting should be required
I didn't need to flute mine. The rudder is straight, and the stiffeners can be used as they are.
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 10-02-2007, 02:48 PM
N787R N787R is offline
Default No fluting should be needed
Normally no flutting is needed.
When I did mine, I made a mistake in cutting the stiffners in the right way thinking that the hole positions are all the same.
But they are not. That made me think that I have to do fluting to get the stiffners match the holes.
But I realized my mistake and had to order new stiffners and do it the correct way.
B
Old 10-02-2007, 03:10 PM
scard's Avatar
scard scard is offline
If they are coming out a little bowed after dimpling, make sure you are dimpling hard enough. Too light of a dimpled row of holes will clearly curve the piece.
Scott Card
CMW E-Lift
Old 10-02-2007, 04:58 PM
rwarre rwarre is offline
Default At the same stage
I am also working on rudder stiffeners for my 7A and found that when I match/drilled the holes the alignment was off maybe 1/32 or less. A slight pull to one side lined them up.
Old 10-03-2007, 06:27 AM
DaX's Avatar
DaX DaX is offline
I only flute if a row of holes isn't straight. You can hold a steel rule up to the bottom of a line of holes to check. The worst part so far had to be the top rudder tip rib - mine is heavily fluted.
My stiffeners had a slight slight bend in them, but I put 3 clecos in each (one on each end and one in the middle), and started at the center between clecos and worked outward toward the clecos. I have nice flat rudder skins.
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 10-03-2007, 10:08 AM
Mhead's Avatar
I back riveted the stiffeners on both skins this morning without fluting and they came out nice and straight. Thanks for the comments.
Gary Moore
Northwest Arkansas
Donated 9/9/19
