w/a Donation
VAF on Twitter:
@VansAirForceNet
  #11
Old 09-17-2023, 10:35 AM
vic syracuse vic syracuse is offline
Super Moderator
Default Original Clevelands are marginal.
Originally Posted by Auburntsts View Post
Meh. All the systems work—IMO you can’t go wrong with any of them. You’re not stopping a fully loaded 747. I’ve got Grove and they work just fine.
The original Cleveland brakes on the 10 are marginal, at best. You may only need them to work really hard once, and they won't. The fade really quickly with hard stopping. I needed them once. Suffice it to say Marco brakes were installed as soon as I got home.
George Happ at Matco continues to improve upon them as well.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, Hummingbird helicopter, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES/RW
Kitplanes "Unairworthy" "Diagnostics" monthly feature
EAA Sport Aviation "Checkpoints" monthly column
Author "Pre-Buy Guide for Amateur-Built Aircraft", "Are your Nuts Tight?" &"Maintenance Guide for Vans RV Aircraft."
www.Baselegaviation.com
Old 09-17-2023, 11:03 AM
Auburntsts's Avatar
Auburntsts Auburntsts is online now
Vic
Point taken. I was referring to the current options (MATCO, Grove, and Berringer) which I don’t believe include Cleveland so I should have been more clear in my OP.
PP ASEL-IA
RV-10 N728TT - Flying!
EAA Lifetime Member
WAR EAGLE!
Old 09-17-2023, 05:18 PM
Originally Posted by KatanaPilot View Post
I think you might find that the stock brakes are marginal to potentially inadequate on a fully loaded RV-10 (especially with an increased gross weight above 2700 lbs) and ….
I have the original Clevelands and agree with others, they are a bit on the marginal side, especially if hot. But I also think it’s unfair to invoke over-gross operations. Once you go down that rabbit hole there are lots of things that get ‘marginal’.
Old 09-17-2023, 07:29 PM
KatanaPilot's Avatar
KatanaPilot KatanaPilot is online now
Didn’t want to follow you down the rabbit hole, but there is engineering justification for increasing the maximum gross takeoff weight above 2700 pounds if you have extended range tanks. All the more reason to have adequate brake energy available for an RTO at gross weight.
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - donated to Fernandina Beach High School
RV-7A Phase 2 (Honored to be Van's "Miss July" 2021) - now at her new home in Lakeville, MN
RV-10ER Phase 2. In paint at Evoke! Penn-Yan IO-540, dual bus SDS EFII, Hartzell composite prop, Showplanes cowl, Airflow Systems A/C, Garmin IFR panel by SteinAir, Aerosport interior, carbon fiber panel and overhead console, Mountain High O2
EAA Technical Counselor
Old 09-21-2023, 11:18 AM
brettwmyers brettwmyers is offline
What is that justification, exactly? I am installing ER tanks and am curious...
Old 09-21-2023, 11:28 AM
The very short answer is that additional fuel in the wings reduces wing bending.
Suggest you get a copy of Ken’s engineering report for the ER tanks and have a read. It’s pretty thorough and even so - not a bunch of engineer speak.
Ken is quite adamant about increasing only the MTOW and not the MLW.
Krea Ellis
Locust Grove, GA
