w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 09-04-2023, 08:33 PM
bkc3921's Avatar
bkc3921 bkc3921 is offline
Default Mis-manufactured F-00055 L1 and R1 Garmin support bracket
Section 42, Page U-04..There are 2 support brackets (F00055L and R) for the back side of the Garmin radio tray. There are 3 holes to attach them to the panel base with LP4-3 rivets. The holes are equidistant at about 5/8 apart.
The F00055's I was sent have the 3 holes...but none of the holes are equidistant, and do not match the pre-punched holes in the panel base. They cannot by match drilled, as they would be too close to existing holes in the base.....in other words, it doesn't fit and there is no fix.
I'm hoping this is a one-off, and I will be calling Van's tomorrow for a replacement. Apparently just a punching error, but if you are in the avionics kit, you may want to check yours so you don't get delayed on your build. Just a heads-up...I hope I'm the only unlucky guy with this small issue.
Brian K. Morrow
DuBois,Il
N433BC "Muttley" RV-7A Flying
N433BM "Dastardly" RV-12is EMP, FUSE, WINGS, POWERPLANT Done...FINISH and AVIONICS in PROGRESS
Official Repeat Offender
"Maintain thy airspeed...Lest the earth arise and smite thee..."
Old 09-06-2023, 09:03 AM
bkc3921's Avatar
Default Solved/Update
Called Van's about these parts...they were definitely mislabeled at the factory, and Van's said will check their inventory to insure this does not happen again. The new, correct parts are on the way. As usual, great customer service.
Brian K. Morrow
DuBois,Il
