Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
09-03-2023, 04:10 PM
Cowl exit air attach brackets
9A here with screws for the cowl lower attach points instead of hinges.
Finally figured out how the exit air attach brackets mount and am considering leaving it off. The cowl seems solid without it.
Has anyone left this assembly off, or is that a bad idea?
09-03-2023, 08:11 PM
Exit air attach bracket? The thing that keeps the coal shovel from vibrating/flexing itself to death?
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019? (actually 2022) RV-10 N46BX
09-03-2023, 08:59 PM
Yes, it seems it's purpose is too stabilize the bottom of the cowl somewhat in addition to giving you something to attach a small trim plate that covers the slot for the nose gear. Additionally, it captures the ends of the hinge pins if you go that route.
I don't know for sure, but the trim plate may contribute to directing cooling air.
09-03-2023, 09:00 PM
Your call, but my sense is that you risk fatigue cracks in your cowl if you leave it off for long.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
09-03-2023, 09:15 PM
It might surprise you how much internal air pressure is pushing outward on that part of the cowl in high speed flight.
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips, ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR & Pre-purchase inspection Services
A&P, EAA Technical Councelor
09-04-2023, 12:26 AM
Buttoning up the bottom of my lower cowl noticeably contributed to lower engine temps. Air pushing up through the slot for the nose gear seemed to disrupt the proper flow of cooling air traveling down from the cylinders and out the chute. Once I had all the brackets and fairings in place to cover the slot, my CHT’s dropped. The cowl exit attach bracket helps secure the bottom to ensure proper airflow.
David Lewis
N647X
RV-7A, KWHP
09-04-2023, 09:38 AM
I suspected that might be the case. Based on feedback received here and from others, I'm going to go ahead and put it on.
Thanks for all the replies.
09-04-2023, 09:49 AM
Good call!
Jake
RV6 #20477 completed 1991 sold.
RV7 #72018 N767T first flight 11/21/2017
(KOXC)Oxford, CT, (0NY0)North Creek, NY.
1941 J3 Cub skis, floats.
Current Project Javron Super Cub
Thank You Doug!
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
