Old 09-30-2007, 11:50 PM
szicree szicree is offline
Default Light Speed Power Connections
When Klaus says to wire this thing straight to the battery posts, does
he really mean straight to the battery posts?? No ground block? No fuse?
Also, as long as we're here, what sort of connection are folks using on the Odyssey battery? It came with some little "L" brackets and bolts, so I assume its my choice to use them or just bolt straight into the battery.
Boy, it's hard to believe this little battery is gonna crank that big ol' motor.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 10-01-2007, 01:27 AM
Walt's Avatar
Walt Walt is offline
Default Yep!
Seems they may be suceptable to noise and/or voltage spikes and connecting right to the battery is the best way to minimize this.
Get rid of the "L" brackets and connect to the battery.
Don't worry, these batteries work great!
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 10-01-2007, 10:29 AM
kentb's Avatar
kentb kentb is offline
Default I did put a fues inline with mine.
But it is always hot off of the battery.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 10-01-2007, 10:45 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Yes, you want the power lead to bypass your normal bus. I installed a battery bus next to the battery and connected my EI, as well as my clock circuit from the EFIS to the bus and used blade fuses to protect the circuits.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
