w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 08-31-2023, 09:27 AM
KEG KEG is offline
Default Priming Fiberglass Parts
The 12iS includes several parts manufactured from "FIBERGLASS-POLYESTER", "FIBERGLASS-EPOXY" and/or "E-EPOXY" per KAI sec.4. The difference in these materials is unknown to me.
My question is: What type primer to use on these parts until I can finish my project, fly it and, eventually, get the plane painted professionally? I would prefer a 'rattle can' product but I do have some spray equipment.
Ken
First time builder
RV-12iS, Garmin IFR
Tuscumbia, Alabama
Old 08-31-2023, 09:38 AM
Most, if not all fiberglass parts on the RV 12 are supplied with a gray gelcoat coating on the exterior. This doesn’t require any primer prior to flying. The only fiberglass that will require some finish work prior to flying is the fiberglass work that is done during the build of the canopy. For that, any rattle can primer listed as high billed would be acceptable. Being high build will provide a surface good for finish sanding.
Opinions, information, and comments, are my own unless stated otherwise.
You are personally responsible for determining the suitability of any tips, ideas, etc. obtained from any post I have made in this forum.
Scott McDaniels
Hubbard, Oregon
Formerly of Van's Aircraft Engineering Prototype Shop
FAA/DAR & Pre-purchase inspection Services
A&P, EAA Technical Councelor
Old 08-31-2023, 12:27 PM
FlyingDiver FlyingDiver is offline
Something like this? https://www.aircraftspruce.com/catal...clickkey=88826
I had to extend the edges of my cowl due to trimming them short, so I have exposed fiberglass in those areas. So I'd like to just do the whole cowl so it doesn't look quite so bad.
Joe
2023 Donation Paid
RV-12iS In Progress
Empennage, Wings (except nav lights), Fuselage done
Working on Finish kit, Avionics, and Powerplant
Old 08-31-2023, 12:42 PM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Don’t forget the inside of the cowl. Prime to seal it from oil and such. Any good two part epoxy primer works, and if the primer is not white then put a top coat of rattle can white on top to reflect heat.
Carl
Old 08-31-2023, 01:08 PM
Carl
Not so much necessary on an RV-12 cowl because they are manufactured using a wet layup process with regular expoxy resin (not prepreg).
Scott McDaniels
Hubbard, Oregon
Old 08-31-2023, 01:09 PM
I like the SEM products.
Should be a good choice, though I haven't ever used that specific one.
Scott McDaniels
Hubbard, Oregon
