Old 09-30-2007, 12:34 PM
prkaye prkaye is offline
Default holding washers
is there a special technique, or tool, for holding little washers in position? In places like where you have washes next to rod end bearings to fill the gap between the bearing and the clevis, i find holding those washers in position while i try to slip the bolt through, to be very tricky.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 09-30-2007, 12:42 PM
Frustrating, isn't it?
I've used tweezers for that application, but mostly, I take a 1/2" or narrower strip of aluminum and cut a v-shaped notch in one end to give the washer a notch to rest in. Then I put a piece of duct tape on the little aluminum strip and leave just a little of it exposed over the v shaped notch. The tape will keep the washer from falling out of the notch.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 09-30-2007, 12:43 PM
jlfernan's Avatar
jlfernan jlfernan is offline
Go to Averytools.com. Washer wrenches.
http://www.averytools.com/p-242-washer-wrench-set.aspx
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 09-30-2007, 01:35 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Run a piece of string or fishline through all the holes with the washers included in their proper sequence. Pull the string taut and all the washers will pull up into their proper location.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 09-30-2007, 01:40 PM
mgomez's Avatar
mgomez mgomez is offline
Default Avery wrenches make a big difference
Avery's washer wrenches make a big difference. I was 3 years into my project before I learned about them. It makes it a little less frustrating, but you still need to buy two or three quarts of patience from Aircraft Spruce.
Martin Gomez
Redwood City, CA
"My RV-7 is a composite airplane: it's made of aluminum, blood, sweat, and money"
RV-7 Slider QB
Old 09-30-2007, 01:55 PM
Rene Bubberman's Avatar
Rene Bubberman Rene Bubberman is offline
Default simple tool
I made some very simple tools from scrap plastic, see http://websites.expercraft.com/PHVII...ry&log_id=8717
Just make them (about) the same thickness as the washer and make one for every size of washers. Costs: zero, savings on frustrations: huge
Ren? Bubberman
PH-VII | RV-7 | tip-up | FADEC
Flying | 480 hours
http://websites.expercraft.com/PHVII/
PH-RVP | RV-7A | slider
Flying | 5 hours
http://websites.expercraft.com/phrvp/
Old 09-30-2007, 03:13 PM
ao.frog ao.frog is offline
Default Grease here
I put alittle grease on each side of the washer and place it in position.
The grease holds it steady while you put the bolt in.
I'm careful not to put grease on parts which later will be primed or painted
Regards Alf Olav Frog / Norway
Old 09-30-2007, 04:34 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default More techniques
Sometimes I put electrical tape around the outside of the washers. Sometimes I grab the edge of one with a forceps (cheapo version). Then try, and try...
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 09-30-2007, 04:40 PM
Rivethead Rivethead is offline
I used the same tape method but I use thin scotch tape and only attached it to one side. I did buy the tool from Avery and have since stopped worrying about it.
Old 09-30-2007, 11:09 PM
briand's Avatar
briand briand is offline
Dbl.-sided tape stuck on the end on my 24" steel rule. Place the washer on the tape with the hole hanging completely off the end of the rule. When the washer is on the bolt give the ruler a tug and your good to go.
Works for starting nuts too. Like the ones that go in-between the wing c-sections.
