safeair pitot
Hi steve, I just recieved my denon pitot system. It's polyethelene I believe. Two colour blue and green. It comes with quick connector tees for adapting to the other instuments. Their system comes with a warning not use any other quick connectors with THEIR proprietary lines because of the posibility of leaks. The system will be very easy to install. One can order the fittings separately and simply splice in a tee and add the adapter that transitions from the tubing to the denon threaded fitting. Try giving safeair a call they may even send you a few feet of tubing. You never know.
btw: Their static tubing is DOT listed white air-brake tubing.
Lorne
RV 7a tip-up
Pre-cover MD-RA Inspected.
