Old 06-29-2005, 07:27 PM
collinsj57@adelphia.net collinsj57@adelphia.net is offline
Default Balancing elevators ?
Balancing elevators ? What?s the best way to balance them with manual trim, if I leave the cable in it will offset the balance due to its stiffness, if I leave it out I am not accounting for its weight? Any suggestions?
John Collins
South Central PA
RV6A Phase II
Old 06-29-2005, 08:19 PM
DGlaeser DGlaeser is offline
Balance them without the trim cable. Make it a touch nose heavy to account for paint later. Since there is trim cable both forward and aft of the hinge line, it is balanced (close enough for our purposes). This balance should be as close as you can get it, of course, but is not hyper-critical.
Dennis Glaeser
RV7A Empennage
Old 06-30-2005, 04:19 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
Dittos on what Dennis wrote.
Roberta
