Old 09-28-2007, 05:50 PM
szicree szicree is offline
Question CHT Probe Install Question
The little bosses that screw into my engine for the CHT probes seem to have no washer or tab or anything to keep em in. The instructions from GRT have no torque spec either. Anybody know the correct procedure for these?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 09-29-2007, 02:14 AM
penguin penguin is offline
Just screw 'em in until they're snug, the probes are spring loaded and will keep everything in place. If you screw the boss in too tight with a small screwdriver it will break, use the largest screwdriver that will fit.
Pete
Old 09-29-2007, 09:13 AM
az_gila's Avatar
az_gila az_gila is offline
Smile Anti-Seize
I just checked the STC'd instructions that came with my GEM engine monitor, and no torques are given. As Pete said, the springs help here...
They do mention that anti-seize should be used, which makes sense given the dissimilar materials involved...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
