Old 09-27-2007, 02:26 PM
Captain Mike Captain Mike is offline
Default WARNING! Firesleeve throttle and mixture controls.
WARNING! Firesleeve throttle and mixture controls! Ask me how I know. With appx 300 hours on my first RV-8 the throttle and mixture cables (Van's green type)became very difficult to move. The cables were not close, in my opinion, to any heat source, ie the exhaust pipes. Closest was 5.5 inches but never the less locked up over time. Both cables are now removed from aircraft to be replaced with new and FIRESLEEVED all the way to firewall. The removed cables cannot be moved at all by hand but have no external damage.
Hard way to learn this lesson as those cables including throttle quadrant had to be removed from completed aircraft to replace with new.
Mike Ballard
Building RV number 4
Flying RV-8 number 2
Sold RV-8 number 1 & RV-6A
Old 09-27-2007, 02:28 PM
dan's Avatar
dan dan is offline
I used reflective heat tape on my throttle cable instead of firesleeve. My theory was -- firesleeve will resist flame, but may not "reflect" typical radiant heat as well as other things can. But I totally agree with you in principle about doing your best to keep heat away from those cables.
Dan Checkoway RV-7
Old 09-27-2007, 02:47 PM
frankh's Avatar
frankh frankh is offline
Default Or...
How about using auto store fuel hose slit down the side for insulation covered in reflective tape?
Frank
Old 09-27-2007, 02:56 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Go look for a thread by Paul Dye about a similar problem, turns out the actual cause was electrical-------throttle cable provided a ground path.
Do you have a ground strap from the engine to the firewall???? Or at least back to the mount on the other side of the rubber mounts??
I have had the same problem in VWs, and Porsches.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-27-2007, 05:03 PM
Ironflight's Avatar
VAF Moderator / Line Boy
In the interest of keeping the record straight, I never made that determination Mike. What I DID find was an area of discoloration right at the point where the cable was stiff, and the inner diameter had shrunk to where it bound on the moving core. This was directly over the exhaust pipe spreader - there was a part of the cable closer to the pipes that was not constricted. The discoloration looked like chlorine corrosion, although I don't really think that is what it was. I never came up with a good cause, but did replace both mixture and throttle eventually, and agree that insulation of some sort is a good idea - can't hurt! (I have several ground straps that are carrying the engine load, so I don't think it could have been that.)
Changing the cable at the quadrant is a horrible pain,....but easier the second time around!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 09-27-2007, 10:09 PM
Flyrod Flyrod is offline
Default NAPA can help with heat
Hey, funny this thread came up today as I just came from NAPA and picked up about $100.00 worth of heat mediation gear. If you look at their performance catalog, there is a company that specializes in heat mediation and control materials. The control cables are one of my targets as well as the fuel pump. I also picked up some exhaust wrap to help pump more heat out the cowling. Ordered a 90 degree elbow from Vans with tubing to get heat muff hot air out of the cowling when cabin heat is shut off which is most of the time here in Florida.
RV8 "Gladder's Gal" #80707
Superior IO360 B1B 193 HP, Whirlwind 151-69"
IFR-Dual Cheltons, Crossbow NAV 425EX
Garmin 430/SL30/330 Mode-S w/ traffic
Ryan 9900B TCAS, WSI AV300, S-Tec 55X
Searey 80 HP
Old 09-27-2007, 10:33 PM
Mike S's Avatar
Senior Curmudgeon
Paul
Paul, sorry, my mistake.
My poor old brain just aint up to remembering as well as it used to.
Anyway, I looked up the original thread about your cable---mixture---and the comment that I remembered about the ground problem was by "Monkey".
However, a bad ground can cause this type of problem.
Right thread, wrong post.
Mike Starkey
VAF 909
Rv-10, N210LM.
