View Poll Results: When you fly cross country...
Fly VFR and File Flight Plan 10 8.26%
Fly VFR and Use Flight Following 52 42.98%
Fly VFR and Use XM Weather 22 18.18%
Fly VFR, File Flight Plan and Use Flight Following 15 12.40%
Fly VFR and, File Flight Plan, Use Flight Following, and Use XM Weather 5 4.13%
Fly VFR and Go it alone 40 33.06%
FLy IFR 12 9.92%
Fly IFR and Use XM Weather 13 10.74%
Selected more than one - I fly based on weather. 34 28.10%
Selected more than one - I fly based on distance. 12 9.92%
Multiple Choice Poll. Voters: 121. You may not vote on this poll
Old 09-27-2007, 02:11 AM
n468ac's Avatar
n468ac n468ac is offline
Default When flying cross country I use?
When you fly cross country you...
(This post by: Christopher Checca EAA Lifetime Member #799388)
Allen Checca (father)
Christopher Checca (son)
RV-6A - N468AC
ENGINE: Lycoming 180 HP O-360-A1A
PROPELLER: Senisentch 72FM859-1-85
WEIGHT: Empty Aircraft 1152 lbs
BASED: KC09 - Morris, IL.
Flying since June 6, 2005
N468AC Web Site
Old 09-27-2007, 08:55 AM
frankh's Avatar
frankh frankh is offline
Default I selected more than one
Depends a lot on the geography.
If its say 100 miles in the willamette valley then its VFR possibly with flight following.
If its crossing the mountains its a minimum of VFR+FF and possibly IFR
if the WX looks at all dodgy I file IFR and cancel if I don't need it..Easier than doing it the other way round.
Quite often I get ATC being unable to do FF cus of workload. Thats a risky situation if crossing the mountains lest I end up doing a Steve Fossett...I want someone to know where I'm at.
Frank
Old 09-27-2007, 10:26 AM
captainron's Avatar
captainron captainron is offline
I didn't see the choice for "Fly NOE and depend on search and rescue!"
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
