09-24-2007, 11:53 AM
Alternator Alternatives
Ready to mount my alternator and am leaning towards Plane Power. How are these holding up?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built  and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
09-24-2007, 12:09 PM
I've got about 42 hours on mine now.
It's working like a champ so far. It keeps my voltage absolutely nailed. They're a fairly new outfit from my understanding so there probably aren't that many flying with a huge number of hours on them.
The machining and attach hardware are top quality.
09-24-2007, 12:38 PM
Same as Jamie, PP is the only way to fly. I have about 100 hours on mine now. Rock solid @ 14.4v.
http://www.plane-power.com/
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
09-24-2007, 01:29 PM
150 hours
13.8 V...Thats what its ajusted too...A bit on the low side but apparently in spec and rock solid.
Frank
09-24-2007, 02:05 PM
I installed a salvaged Nippon Denso alternator from a Suzuki Samurai per this builder's site. I paid $35 for the alternator. It worked flawlessly for the 300 hours that I put on it.
http://www.f1-rocketboy.com/alternator.htm
Frank, is that measured off the avionics bus? And do you have a diode betweent he main and avionics bus?
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
09-24-2007, 03:05 PM
My B&C L-60 has over 900 hours on it and is doing fine. A few more bucks, but hard to beat, IMHO. Started on a 6A and is now on my 9A. It does require a regulator.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
09-24-2007, 03:13 PM
Bob Kelly
1425+ hours on my B&C L40. Worth every friggin extra penny for "get in and go" reliability. I fly enough to warrant the expense for the convenience.
Ask Gary Sobek what original alternator he still has in his 2000+ hour RV-6. B&C
Dan Checkoway RV-7
09-24-2007, 03:31 PM
Duh....?
I honestly can't remember where the sensor is wired to...Probably the battery buss and I use a Shotkey diode anyway which has a pretty low forward volt drop I believe.
Seems to charge the battery OK though.
Frank
09-24-2007, 03:34 PM
Thats how I started
But I used the Toyta Camry 60A beast...Worked great but one day my GNS 430 went beserk and as this is an IFR airplane I could'nt be doing with that...But it turned out the idiot who made the brackets (that would be me) decided to paint them...Thus providing a nice insulation layer between the alt and the engine block.
i discovered this as I was pulling it off to install the plane power unit.
I can't believe I made such a bonehead mistake!
Anyone need a new Camry alt, v pully and brakets to bolt it to a Lycoming?...
Frank
