09-23-2007, 01:51 PM
Float Fuel Sender Wire Length
RV-8A QB so I haven't had much fun with fuel tank stuff. I'm trying to install the float-type fuel senders that arrived with the first kit 2+ years ago. Not much room in the tank for measuring. In referring to drawing 16A, Van's gives the wire length dimensuions as "Approx. 3 inches" for both segments. However, the 1/2 scale drawing view shows them over 4". Supposedly there is a separate data sheet from Vans showing the exact dimensions, but I can't find it. Also, I checked the archives without finding dimensions, but found folks discussing different measurements for the left and right tanks. I'm clueless on that one.
Anyone know what the bent lengths were for your float senders?
Paul Valovich
N192NM Reserved (again)
Ridgecrest, CA
09-23-2007, 05:15 PM
Paul,
This came courtesy of Paul Dye. Vans includes this sheet with the sending units, but I didn't get one. Hopefully the picture will suffice. The left wing calls for 3 1/4" per side and the right is 3 3/16". Don't forget the 3/4" bend to lock the wire in the sender keeping it from rotating. Ask me how I know. If you mess up a bend, hinge pin works as a substitute. Hope this answers your question!
Rocky McKiernan
Navarre, FL
N767JM RV-7 Flying
N1011D (res) RV-10 Building
09-24-2007, 08:39 AM
Rocky,
Thanks - just what I needed. But it does bring up more basic questions of the effectivemness of my admin procedures and filing system. Doesn't do much good if you can't find it when its needed.
Booger
01-30-2008, 12:24 PM
Anyone have this drawing
The photo or link seems to have been removed. I didn't get one with my senders either.
Bill Woods
RV8 sold  180 hrs. of pure joy
(Nov 2018) Bought 7A Tip up
project, converting to tailwheel
slider (just because)
Thunderbolt YIO390
Hartzell BA
Steinair Panel (WOW)
01-31-2008, 04:51 AM
Float Wire
Come on Guys, someone must have this diagram. I could bend by the plans but I've read that one side is slightly different from the other.
Bill Woods
Thunderbolt YIO390
Hartzell BA
01-31-2008, 07:44 AM
E-mail
I'll e-mail you a scan later today.... gil A
BUT - you can't hide your e-mail address on VAF if you want a copy....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-31-2008, 09:49 AM
Thanks Gil
I do not have my email hidden but comes up that way for some reason.
kolbpilot@msn.com
Bill Woods
Thunderbolt YIO390
Hartzell BA
