I copied the class information from the website
http://www.sportairrace.org below. Membership in the SARL is free and the website is basically open to anyone (there is a small members only section). From what I have experienced so far if a race organizer gets a SARL sanction they must provide the opportunity for every class to race. I do not know what the displacement of your engine will be but depending on that the most likely classes would be Formula: RV-T Red or blue or UNLIMITED if the engine displacement is over 360 cu. in.
The Race Classes
UNLIMITED Any Experimental Category aircraft with a turbocharged engine with a displacement of 1400 cubic inches or less. Class winners in both Fixed and Retractable gear.
SPORT CLASS Any Experimental Category aircraft with a normally aspirated engine with a displacement of 1000 cubic inches or less.
SPORT FX Any Experimental Category aircraft with 550 cubic inch displacement normally aspirated with Fixed Landing Gear for RV-10s, F-1 Rocket, Harmon Rocket II etc.
FORMULA RG Blue Any Experimental Category aircraft with an engine displacement of 360 cubic inches or less, normally aspirated, with retractable landing gear.
FORMULA RG-T Blue Any Experimental Category aircraft with an engine displacement of 360 cubic inches or less, turbocharged, with retractable landing gear.
FORMULA RG Red Any Experimental Category aircraft with an engine displacement of 320 cubic inches or less, normally aspirated, with retractable landing gear. FORMULA RG-T Red Any Experimental Category aircraft with an engine displacement of 320 cubic inches or less, turbocharged, with retractable landing gear.
FORMULA FX Blue Any Experimental Category aircraft with an engine displacement of 360 cubic inches or less, normally aspirated, with at least two fixed landing gear.
FORMULA FX-T Blue Any Experimental Category aircraft with an engine displacement of 360 cubic inches or less, turbocharged, with at least two fixed landing gear.
FORMULA FX Red Any Experimental Category aircraft with an engine displacement of 320 cubic inches or less, normally aspirated, with at least two fixed landing gear.
FORMULA FX-T Red Any Experimental Category aircraft with an engine displacement of 320 cubic inches or less, turbocharged, with at least two fixed landing gear.
FORMULA RV Blue Open to Van's aircraft RV-3, RV-4, RV-6, RV-6A, RV-7, RV-7A, RV-8, RV-8A, RV-9, and RV-9A airplanes powered with an engine of 360 cubic inches or less, normally aspirated.
FORMULA RV-T Blue Open to Van's aircraft RV-3, RV-4, RV-6, RV-6A, RV-7, RV-7A, RV-8, RV-8A, RV-9, and RV-9A airplanes powered with an engine of 360 cubic inches or less, turbocharged.
FORMULA RV Red Open to Van's aircraft RV-3, RV-4, RV-6, RV-6A, RV-7, RV-7A, RV-8, RV-8A, RV-9, and RV-9A airplanes powered with an engine of 320 cubic inches or less, normally aspirated.
FORMULA RV-T Red Open to Van's aircraft RV-3, RV-4, RV-6, RV-6A, RV-7, RV-7A, RV-8, RV-8A, RV-9, and RV-9A airplanes powered with an engine of 320 cubic inches or less, turbocharged.
SPRINT CLASS Any Experimental Category aircraft with an engine displacement of 240 cubic inches or less, normally aspirated.
SPRINT-T CLASS Any Experimental Category aircraft with an engine displacement of 240 cubic inches or less, turbocharged.
SPORSTMAN Any Experimental Category aircraft using a VW or Corvair normally aspirated engine conversion
SPORSTMAN-T Any Experimental Category aircraft using a VW or Corvair turbocharged engine conversion
FAC1 Normally Aspirated Twins
FAC1-T Turbo Normalized Twins
FAC2 250-360 HP, Normally Aspirated
FAC2-T 250-360 HP, Turbo Normalized
FAC3 150-225 HP, Normally Aspirated
FAC3-T 150-225 HP, Turbo Normalized
FAC4 100HP and below, Normally Aspirated
FAC4-T 100HP and below, Turbo Normalized
