The best thing about this website is that somebody always knows an answer for the question, so here it is:
I forgot to notice or take photos when I removed my O-320 of the fuel pump fittings. On the outlet side I remember that there was a combination fitting or fittings for outlet and fuel pressure. Is there a recommendation in the plans or some type of standard fittings? Can you use aluminum fittings anywhere in the fuel system?
Steve
