It's OK
Phil... if I read your description correctly, this is normal.
The standard rivet sets do not completely conform to the manufactured head.. if they did, then you would get "smileys" in the aluminum around the rivet if you were just a degree or two off normal. Because of this, they "hit" more on the crown of the rivet head than the edges.
There is a specification for the manufactured head height after riveting. It is on my web site....
http://home.earthlink.net/~gilalex/r...ec/rivet_a.htm
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Reason: added sentence
