Originally Posted by dlloyd3
What are the pros & cons of electric elevator trim versus the manual trim cable?
I have 2 axis electric trim (elevator and aileron) activated via a "china hat" on an Infinity joystick grip. The LED indicator lights mounted on the instrument panel show how much deflection is cranked in at any given time. Unlike some RV-6A drivers, I find the elevator trim sensitivity to be a non-issue whether at full throttle or in the pattern. This may be due to the adjustment screw being set just right on the ES-MK-111 (speed controller and relay deck) from the get go. I have not felt the need to readjust it. My guess is that sensitivity may be a problem if this optional component is not installed. Until I started flying my RV, I had no real concept of how just how much difference a few gallons imbalance in each fuel tank can effect the centering of the joystick. The electric aileron trim is often used to compensate for fuel imbalances at any given moment. I could not be happier with my electric trim system and plan on installing exactly the same components on my RV-8 kit someday.
I have flown an RV-6A with manual elevator trim and it works perfectly fine. My only issues with the set-up are that it is a rather large assembly and I didn't want a center console installed on my plane (per plans) and at least on the particular aircraft I flew, you had to neutralize the trim tab during preflight by visually sighting it and adjusting the trim wheel in the cockpit because no cockpit elevator trim indicator of any sort was installed.
Like everything else, whatever you install is a choice that ultimately comes down to personal preference.
Rick Galati RV-6A "Darla" 36 hours
