Old 09-17-2007, 09:18 AM
jlfernan's Avatar
jlfernan jlfernan is offline
Default Extra Aluminum Bar
I'm almost done with my 9A QB fuse except for mounting the empennage and wings. I have two aluminum bars, one tagged AB4-125X1 1/2X8 and one tagged AB4-125X1 1/2X10 in my inventory. I can't figure out what they're for? I hate having that "I think I forgot something" feeling. Help restore my sanity.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 09-17-2007, 04:40 PM
gbrasch gbrasch is offline
Guest
Default Have You Checked Section 4?
Have you checked section 4 of your manual which lists every part number, and in addition, the drawing that part number is on?
Old 09-18-2007, 06:18 AM
jlfernan's Avatar
I checked that section unfortunately the AF4125 x 1 1/12 x 8 on the tag is the physical description of the piece, not a part number. The parts that use these materials are always shorter and sometimes two parts are made out of the same piece of aluminum. I'm having a hard time figuring out what parts should be made out of these pieces.
Jorge Fernandez
Spruce Creek, FL
Old 09-18-2007, 09:10 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
IIRC, one of them is the battery hold down piece used with the firewall mounted Odyssey battery box kit.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 09-20-2007, 07:53 AM
jlfernan's Avatar
OK, how 'bout the other one?
Jorge Fernandez
Spruce Creek, FL
Old 09-20-2007, 08:56 AM
Mike S's Avatar
Senior Curmudgeon
Sorry dude-------------51% rule, I can only tell you about one of them.
You have to do the rest yourself.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 09-20-2007, 11:51 AM
Steve Steve is offline
Could it be the spacer under the aft deck (the big triangular part) that the forward HS brackets bolt through?
Steve
Old 09-20-2007, 12:08 PM
Rick S. Rick S. is offline
NOW THAT'S FUNNY!!!!
Rick Sked
Old 09-20-2007, 04:59 PM
jlfernan's Avatar
Hey Steve,
It might be. I know I received materials for parts that were already done in the QB, I just couldn't place these.
Jorge Fernandez
Spruce Creek, FL
