Howdy y'all! Long story short, I'm having some yard work done and after breaking up a concrete slab, the dust made it into the garage via a vent and put a good size layer of concrete dust on everything including finished pieces (VS, HS, Rudder), and parts to be primed.
Question: Is it corrosive? What's the best strategy for removing it, or should I just leave it for now?
I'm worried about scratching if I'm wiping it off dry with a microfiber, and blowing it off, I imagine, would just lift it only to return.
Also, I left it on a rack, uncovered because I've heard of stories where plastic trapped humidity, as well as blankets, leading to corrosion.
Very open to ideas. Thanks everyone!
