No problem here
I had no problem installing one wing on the plane, then moving over to the other side to install the other. It did not tip. I did not have the wing-tips on though.
edit: Well, reread post, and I did not try moving the plane. Probably a very good idea to have someone support the wing while moving the plane.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
