Old 09-14-2007, 11:56 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default 2.25" UMA Altimeter question/issue
Gents,
I have a 2.25" UMA 20K Altimeter I just received for my RV-7A (finishing kit). This my backup altimeter just in case my Dynon fails.
I just checked the barometric pressure in my shop and confirmed it with the local news broadcast (29.93"). I set the pressure window to 29.93" and the altimeter reads 2200 ft. Unfortunately my shop is at 2700 ft. That is 500 ft error.
Now I understand that these single needle altimeters aren't as accurate as the three needle models but 500 ft sure seems to be a significant error.
I choose the 20K model because I was told by UMA that the 10K could be damaged if one exceeded about 11,000 ft.
I don't know about you other fliers but when your being chased by a MIG-21 in your RV, you might need to go vertical and exceed 11,000 ft and damage the 10K model (It's getting late and I am beginning to have delusions ).
Does anyone have any experiences to share about the accuracy of the UMA 2.25" altimeters? I will be calling UMA on Monday to find out if this error is normal or is the altimeter out of spec.
Any info would be appreciated.
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 09-15-2007, 12:04 AM
asav8tor asav8tor is offline
Should be a little screw by the set knob. You unscrew it then pull the set knob out. Now you can change what the altimeter reads relative to the set window.
Old 09-15-2007, 12:58 AM
captainron's Avatar
captainron captainron is offline
I say move your shop up or down the hill to match the altimeter!
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 09-15-2007, 06:49 AM
Mel's Avatar
Mel Mel is offline
The altimeter setting IS NOT the local barometric pressure. The altimeter must be referenced to the barometric pressure at sea level.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-15-2007, 07:29 AM
captainron's Avatar
How do you set yours before your takeoffs from Dallas? What reference do you use?
Ron Leach
Cincinnati
.....Bob Seger
Old 09-15-2007, 08:20 AM
Daver Daver is offline
Default UMA Altimeter
I have the single needle 20K UMA 3-1/8" version I[m going to use in my -9A.
When I set the baro correctly (based on FSS nearby), it pretty much agrees with my GPS & topo map for my location.
Seems fine to me.
Daver
Old 09-15-2007, 08:29 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Use ATIS
Paul... I'm not sure if I would trust the TV news too much...
Set it to the TUS ATIS at 520-741-1177 and see what you get.
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 09-15-2007, 09:32 AM
C. Brenden C. Brenden is offline
Default Setting the altimeter
I'd agree with the asav8tor above. I've set my altimeter using the method he describes. Set your altimeter to the correct field elevation, remove the set screw next to the adjustment knob. There is a tab that this set screw holds in place. It should slide slightly up. This unlocks the altimeter from the baro adjustment. Now set in the correct barometric pressure. (Your altitude should not change while this adjustment is being made.) Slide the tab back to align with the hole for the set screw. Install set screw. The correct barometric pressure will now correspond to the field elevation. I seem to remember being able to set it to within about 30 feet or so.
Old 09-15-2007, 09:54 AM
az_gila's Avatar
Exclamation Smaller altimeter...
That's the procedure for a standard 3 1/8 altimeter that has the little cut out in the bottom left corner. The screw holds a little plate on that is part of the altimeter that fits in the panel cut out.
This 2 1/4 inch altimeter does not have the cut out in the panel, and from the pictures, it does not seem to have a plate there.
Perhaps the knob will just pull out to adjust.... try that Paul....
gil A
Gil Alexander
Old 09-15-2007, 05:34 PM
Mel's Avatar
Mel Mel is offline
My barometer was calibrated with the local airport altimeter settings. I live exactly 1/2 way between two controlled airports (TKI & GVT) and averaged the 2 over a period of time.
BTW the adjustment you guys are talking about is NOT approved by anyone but a certified instrument shop, and not all of them!
