Old 09-13-2007, 08:13 AM
cjensen's Avatar
cjensen cjensen is offline
Default SJ Cowl Plenum/Baffling pics?
For those that have the SJ cowls...can I get some pics of how you made your baffling to go along with the plenum?
Is there any difference in the baffling system between Van's and the SJ cowl?
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 09-13-2007, 08:35 AM
Radomir's Avatar
Radomir Radomir is offline
It's very similar.. sides are same (just not as tall) and main difference is front inlet ramps.. I don't have any pics handy now (sorry).. but it wasn't that big of a deal to do.. I used Van's baffle kit..
Radomir
RV-7A sold
Old 09-13-2007, 08:45 AM
frankh's Avatar
frankh frankh is offline
Default Check this out
A little group I started to help those of us with SJ cowls and plenums.
http://groups.yahoo.com/group/JamesAircraft/
You can either modify a Van's baffle kit or save yourself $200 and make your own from the templates that James supplies...I made my own, simple enough.
Frank
Old 09-13-2007, 08:58 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Info, pics offline
Sam provides drawings and if you have a band saw and a good size brake you can do it. Next best is to use Van's, which I did. You end up leaving out some parts such as at the center of the back and center of the front and you have to cut them down a lot vertically. There was some serious re-bending needed to get the ramps to merge with Sam's plenum at the front. I ended up making some laid-up-in-place fiberglass parts to help seal the front at the bottom of the plenum. There's a difference between Sam and Van on the gaps between lower baffles below the cylinders and Sam says if you follow his guidance your CHT's will be extremely close. I didn't, yet. Mine are maybe 25-30 degrees from hottest to coldest. In general I'm very pleased with the cooling, including oil temps. Fitting the oil cooler is tighter than with Van's. You have to ensure clearance from the fins of the cylinder. I'm sending some pics via email.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 09-13-2007, 09:09 AM
Deems Davis Deems Davis is offline
Default Here's links to photo albums of my install
I installed the cowl and plenum on my RV-10 here's a link to a photo album of the cowl install:
http://deemsrv10.com/album/Sec%2047%...ing/index.html
construction log w/ write up's for cowl:
http://deemsrv10.com/cowlinglogindex.html
Here's a link to an album of the plenum w/Van's baffling:
http://deemsrv10.com/album/Sec%20FF2...num/index.html
Link to construction log w/ write ups for Plenum and baffels:
http://deemsrv10.com/FF2logindex.html
Deems Davis
RV10 N519PJ
http://deemsrv10.com/index.html
Old 09-13-2007, 09:35 PM
TGRV7 TGRV7 is offline
Deems, I am checking out your foto's of your SJ Cowl install.
I see some complex shapes on the baffles. Did you fabricate all the baffles from sheet stock?
I am considering the SJ cowl/plenum/Horz Induction
Does not look like an easy task.
Thx
______
TGudz
EP, TX
RV7
Wire/Elec Phase
Old 09-13-2007, 10:42 PM
Default Nope, I used Van's pre-formed/ cut baffle kit
There are some complex shapes even though Sam sends some paper templates along with the plenum. They aren't super accurate (hand drawn). Most folks I've talked to have opted to use Van's baffle kit and to make the modifications (both to plenum and baffles) necessary to adapt it, rather than cutting the baffles from the templates. I believe that this approach is less work and effort and yeilds a cleaner/more accurate installation. The Baffles and the modifications are really not all that big of an effort relative to the rest of the cowl/plenum work.
Sam warns that the exit area at the bottom of the cyl's is different with Van's and that you need his size area to ensure equal cooling across cyls. I checked and there is a difference in the size of the exit area. However, given all of the other variables, I don't think it's as major an issue as Sam maintains.
Deems Davis
RV10 N519PJ
Old 09-14-2007, 10:40 AM
cjensen's Avatar
Thanks for all the replies, pics, and emails everyone! That helps!
Chad Jensen
Old 09-14-2007, 12:50 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Hey guys, I'm going to buy the Sam James Cowl and was thinking of going with the Plenum. I thought the Plenum didn't need baffeling to work. Am I correct in reading your posts that baffeling is required? Is it used only to attach the plenum to the engine?
Alternately, what if you don't go with the plenum? Is the Van's baffeling sufficient for cooling? What is the benefit to the SJ Plenum? Thanks.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 09-14-2007, 02:51 PM
frankh's Avatar
Default Well
I would go with the plenum...or even make a plenum by taking a 2 layer mold of the underside of you cowl and cutting to size.
less leakage=more speed...It also means more hassle to get to the top of the ngine as well but cst La vie!
Frank
