Possible ....BUT
I guess anything is possible, however, the brake lines need to be installed AFTER the landing gear is attached, And the corresponding brake cyls and reservoir connected. All of this has to be done before the wheel fairings are attached. One builder attached the fairings after the wings were on, but the fairings are a bigger job than most people figure and doing them with the wings on would make it even bigger.
Probably the biggest issue would be the nose gear, the nose gear gets connected to engine mount with some rubber dampeners. All of this is behind the engine case and between the firewall. Take it from one who is recently going through this , that the area between the engine and the firewall gets VERY crowded during the engine and instrumentation connections, doing all of that prior to putting the nose gear on, and then getting the gear attached would be a monumental achievement.
