Old 09-09-2007, 11:33 PM
RV10Rob's Avatar
RV10Rob RV10Rob is offline
Default sanded through the alclad--corrosion issue?
Hi, all.... I've sanded out some scratches in a skin with the maroon scotchbrite pads. For the interior sides, I'm using a self-etching primer, so I figure there's no issue since I'm planning on priming soon.
What about the exterior? I've exposed the aluminum underneath the alclad--should I be worried about corrosion? I'm going to paint it eventually, but not for a couple years at least. I don't want to use the primer on the outside now, since I hear it makes paint adhesion more difficult later. Any suggestions? Unless I hear a better idea, I'm just going to leave any new scratches as-is on the exterior, then sand them down when I get closer to painting.
Thanks...
-Rob
Rob Kochman
RV-10, Flying as of March 2011 (blog)
Paine Field (KPAE)
EAA Chapter 1440
Old 09-09-2007, 11:44 PM
szicree szicree is offline
Are you really sure that you're through the alclad? You'd have to scrub a loooong time by hand with scotchbrite to get through it. I actually tried it once while checking with a micrometer every so often. It took a whole lot o' scrubbing.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 09-10-2007, 02:00 AM
Camillo Camillo is offline
When I re-primed my first empennage ribs, I had to scratch a lot - even with sandpaper - to take all old prime off. And you can easily see the slightly different colour (this was my idea...) detween the pure aluminium and the the alloy.
Anyway, you can now prime and de-prime (and re-prime) with acetone before painting or I think you can apply oil, as Van's does with QBs.
Only my humble opinion...
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 09-10-2007, 05:05 AM
TSwezey TSwezey is offline
Go buy some alodine and rub into the areas that you have sanded. This will protect it for many years.
Todd
N110TD
RV-10 Vesta V8 LS2/BMA EFIS/One formerly flying at 3J1 Hobbs stopped at 150 hours
Savannah, GA and Ridgeland, SC
Old 09-12-2007, 09:52 AM
RV10Rob's Avatar
Thanks, all... on second thought, I may not have sanded through the alclad. I'll check it out again, but it sounds like I might be okay as-is.
Rob Kochman
Paine Field (KPAE)
EAA Chapter 1440
Old 09-12-2007, 11:42 AM
Phil's Avatar
Phil Phil is offline
I've got some alodine that I keep on hand. If I believe I've gone through, I go ahead and spray some on. It makes the part ugly to look at, but once the primer goes on it doesn't matter.
Phil
Old 09-12-2007, 02:38 PM
cytoxin's Avatar
cytoxin cytoxin is offline
Default alclad
is only .002 thick and is buttery soft..comes off redily esp with a RED pad.
just alodine it for now.or sem or any other self etch. good luck.
William Weesner/ still kicking.
Old 09-12-2007, 04:10 PM
FlyerJumper FlyerJumper is offline
Default Touch n Prep
Regarding touchups with alodine, these are nice to have...
Touch-n-Prep Pen
Look around, you can find them cheaper (I think I gave a little over $50 for ours from a local supplier).
Mark
RV-10
On again, Off again Building
...currently Off
Old 09-12-2007, 04:23 PM
Ok, not that it matters, but have you ever actually checked on this? I had seen this statement made over and over on here and other sites until I finally tested it myself. I found that red scotchbrite (by hand) takes a real long time of continuous, vigorous scrubbing. I think a lot of folks are under the false impression that the alclad is gone when the shine is gone.
Steve Zicree
Old 09-12-2007, 04:32 PM
I sand it with 220 grit paper with an orgital sander before I put on the alodine.
Todd
N110TD
