Old 09-09-2007, 09:57 PM
RVG8tor's Avatar
RVG8tor RVG8tor is offline
Default Is this damage or normal
I picked up my second QB kit from Van's, the second one is another story. But after I removed and inventoried the other parts I was looking over the fuselage and the rib that runs down the side of the fuselage down to the wing spar has a buckle in it, this is the same on both sides of the fuselage. I know it did not happen in the move since I moved it my self, and the parts packed into the fuselage did not seem to be hitting the rigs. I see from the plans that a cap (F804N I think) gets riveted onto these ribs.
My question is has anyone else see this or is this damage, and if damaged will this straighten out when the cap gets riveted into place? My worry is since it is on both sides that the rib was compressed because the holes did not line up properly. I do plan to call Van's on Monday but thought I would ask here.
The link takes you to my log page with a photo of the area in question.
http://www.mykitlog.com/users/displa...og=42120&row=1
Cheers
Mike "Nemo" Elliott
RV-8A (First Flight 12-12-12!)
KOCF
N800ME
www.mykitlog.com/rvg8tor
Dues Paid 2019
Old 09-09-2007, 10:10 PM
yakdriver yakdriver is offline
Looks just a little bowed to me. There are no creases or kinks in it. Just srtaighten it out and rivet the cap piece over it and build on. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 09-10-2007, 03:18 AM
Captain_John's Avatar
Looks to me like they used the rudder cable holes for hoisting the fuse.
This type of loading (obviously) isn't what the fuse was designed for.
Look for rivets pulled from their position, cracked sheet metal, and deep gouges.
Those side stiffeners are made from 0.063" stock as I recall. They should be pretty beefy. If they bend back and nothing seems overstressed you might be okay.
What I would do is to locate an experienced local builder and have him look at it.
Good luck!
CJ
The experiment works!
Old 09-10-2007, 04:26 AM
Kevin Horton's Avatar
The similar F-804 bulkhead pieces on my slow build RV-8 were wavy like that too. The inside edge will eventually get covered by a U-shaped channel, and that will pull it straight.
Bottom line - this doesn't look like damage to me. It looks like waviness caused by the metal forming.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 09-10-2007, 04:44 AM
Jack Fromm Jack Fromm is offline
I had a similar issue on my 2001-vintage QB fuselage. It took so much force to pull them straight that I was afraid clecos would not be sufficient to pull them out flush with the caps for riveting. I thought fluting might help so, after consulting with Van's, that's what I did. That helped quite a bit. Before and after pictures attached.
Jack Fromm
RV-8QB - Flying
KDMW - Carroll County, MD
Old 09-10-2007, 06:02 AM
jlfernan's Avatar
jlfernan jlfernan is offline
On my 9A the side walls a straight, therefore those parts remain straight all around. On the 8, the side walls are curved and therefore the angles are fluted to to conform to the curve. When you bend one side of a right angle the other side is going to be longer and that is what is causing the waviness. Vans will probably tell you not to worry. If when clecoing the cover on for drilling and riveting, the clecos don't pull the parts together, I would suggest getting wingnut clecos which are used for pulling parts that need more "pull" than the standard clecos provide.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 09-10-2007, 08:44 AM
TShort TShort is offline
Mine were wavy like that, too - QB from 2006.
I will post pics if you're interested...
The rudder cables go thru the spar box, so lifting by their holes would take some serious force to bend these bulkheads - the spar box, etc would be damaged.
T.
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 09-10-2007, 10:53 AM
TerryWighs TerryWighs is offline
I would be inclined to use the fluting method to align and straighten...If you have to "force" stuff together...(ie. wing nut clecos)....seems this will provide a stress area even after riveting...which may promote stress cracks...IMHO???
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 09-10-2007, 11:54 AM
briand's Avatar
briand briand is offline
Default RVG8tor, I Think I know Exactly What Caused That
When you (or the Phillipinos) draw the two .125 top longerons in to get the proper width for fitting the rollbar thats what happens to the 804's. At least thats what happened to me. Mine aren't that bad but noticable. My longerons may have been bent/formed a little better, I thought they were perfect until I got to fitting the rolbar.
Did you cleco the side covers on yet? How do they fit?
Old 09-10-2007, 04:29 PM
DanH's Avatar
DanH DanH is offline
My 2006 QB also came with the wavy parts. The caps clecoed up just fine, but the fluting idea is a good one and easy to do.
Dan Horton
RV-8 SS
Barrett IO-390
