aft slider canopy track seal w/ meske conversion
For those who have Rich Meske's tip up conversion for their slider, what did you do to seal the aft canopy track. It seems that while you could use the standard nylon slide seal from Van's that is attached to the canopy frame with a little string, doing so would be a pain in the neck having to get that slide seal on and off the track every time you use the tip up feature.
Have you used Van's slide seal with success and without it being a hassle?
or
Have you abandoned Van's slide seal altogether and use no special seal?
or
Have you come up with another alternative?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
