Reamers
I am some what an expert having worn out several handfuls. I use the #40 and #30 reamers everywhere Van?s has pre-punched holes and us the appropriate size everywhere else. You will want to buy the good Cobalt steel ones, only 4 of each will get you though an aircraft.
Examples of proper uses (after you have removed the plastic and de-burred)
1. wing skin to wing rib
a. cleco skin to ribs and ream with a #40 reamer chucked in an air drill
b. use a scotch bright pad to knock loose the burr from the skin and ribs before dimpling
2. landing gear bolts
a. insert the tail of the reamer
b. Lube the reamer with the boeing lube
c. Chuck the reamer in a drill and extract the reamer
i. This will make a straighter hole than trying to push the reamer though. (like pushing rope vs pulling rope)
Notes:
Reamers are cutting tools and should only be turned in one way
Drill bits make triangular holes and reamers make the holes round like your rivets and bolts. Don?t believe me, for show begin drilling a ?? hole in a piece of .032 aluminum and look at the shape of the hole before the drill bit completely passes though the sheet metal.
Noel Simmons
A&P CFI
Builder of fine aircraft
www.blueskyaviation.net
