Old 09-06-2007, 10:45 PM
szicree szicree is offline
Default Filler for Foam Fiberglass Forms
How do you like that alliteration?? So what is the preferred material for smoothing out styrofoam prior to applying glass layups. I'll be throwing away the foam afterwards. Thanks.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 09-07-2007, 12:32 AM
tcone1's Avatar
tcone1 tcone1 is offline
Packing tape works well, and releases very nicely if waxed.
Tim
Timothy Cone
Sierra Skypark (KE79) Fresno CA
RV-8, XP360, RV200
Flown Sept. 12, 2007
1600 hours on the hobbs and loving it
Old 09-07-2007, 07:14 AM
DanH's Avatar
DanH DanH is offline
Tim is right; packing tape works great, if the part is mostly flat. Compound curves will give you some wrinkles and bumps. I'm using red tape in the photo below; that's a biplane cabane fairing.
If the desired part is all curves, coat the foam with any easy-sanding cheap filler. Plain old drywall compound will work. Seal it with a few coats of paint from a rattle can, wax it heavily, do your layups, and dig out the foam from the backside.
Time spent shaping the male mold precisely pays back later when you're finishing the final part.
Dan Horton
RV-8 SS
Barrett IO-390
