Old 09-06-2007, 09:52 AM
prkaye prkaye is offline
Default deburring firewall
I went to deburr all the freshly drilled holes in my firewall last night, but then realised that the stainless steel would likely dull my deburring tool very quickly (that little countersink cutter on the hand deburring tool that you spin around in the hole). So I ran a scotchbright wheel in my hand die-grinder over the surface of the holes a few times. This did an OK job, but the edges of the holes are still a bit sharp.
What have other people done about this?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 09-06-2007, 10:00 AM
tinman tinman is offline
I used a conical grinding stone in a drill motor. I hate working with stainless...
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
Old 09-06-2007, 10:51 AM
fl-mike's Avatar
fl-mike fl-mike is offline
For smaller holes you can use a step-drill / Unibit. Get it (a step) to bite into the burr and run it VERY slowly. It will peel the burr off. Big holes are just a pain. I also use a grinding stone in a Dremel or similar. I hate that smell.
Mike W
Venice, FL
N164WM
Old 09-06-2007, 11:15 AM
thallock thallock is offline
Default Same as everything else
I used the same tool that I have used for the whole project--countersink bit in an electric screw driver. I have several countersink bits, and the deburring bit is always in the screw driver, not used anywhere else. I have no idea if it dulled the bit at all. There's not that many holes to do.
For the edges, I used my files, same as every else.
Tracy.
Tracy Hallock
Austin, Tx
RV-7(EH) - Fuselage
http://www.trv7.com
Old 09-06-2007, 12:10 PM
kentb's Avatar
kentb kentb is offline
Default I used my debur tool
And replaced it. It was about time anyway.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
Old 09-06-2007, 01:28 PM
briand's Avatar
briand briand is offline
Used my deburr tool as well. Didn't notice it get any duller.
Old 09-06-2007, 01:31 PM
mike newall's Avatar
mike newall mike newall is offline
Just been doing it today - braying holes in for eyeball pass through for the mixture !
Small holes, the stepper drill is good - slowly, with lube.
Larger holes, particularly above 1/4" try a small cut off wheel in a dremel at 90 degrees - light touch, goggles on, works really well and leaves a smooth finish.
The new support for the throttle and mixture from Vans works really well on a vertical IO-360, lined up perfectly, makes a change !
