Originally Posted by mistergerf
Anyone got a suggestion for in-line sealing snap disconnects compatible with the plastic lines in an Aerox 2D kit ? (I got the liability blah-blah from Aerox, they wouldn't sell me the parts.)
I want to plumb the kit in semi-permanently. The idea being that I run lines up to somewhere around the panel and then the snap disconnect allows me to remove the cannula and flow meter for stowing when not in use.
I guess the disconnect doesn't absolutely have to be sealing - since I can disconnect the unused line at the regulator, which would also discourage me from leaving the unused line pressurized while the pilot's line is in use.
Also, does anyone know what type of plastic line they use ? Is it plain old clear PVC line ? Smells like it ...
g
I believe the lines are in the Tygon family, and food safe, after all it is going into your lungs....
You don't want to leave the lines pressurized and no mask/cannula plugged in. I did this on my sailplane, and when I landed I had a bulge in the line almost the size on an egg. It was in the low pressure side of the regulator, but I think altitude and temperature effects can cause the O2 to expand in the line.
The Aerox fittings are available here, along with many others...
http://www.wingsandwheels.com/page36.htm
Call Tim (# on the web site) and tell him what you want to do... I'm sure he'll have the parts to make it fit.
gil in Tucson
Usual Disclaimer -- only a satisfied customer, and he has a good on-line catalog...
