Old 09-05-2007, 07:34 AM
rv9aviator rv9aviator is offline
Default Fuselage Stands
Does anyone have a set of wooden fuselage stands that come with a quick build RV-9? I am about to the point of needing something to keep the fuselage off the floor while working on it. I've seen the wooden shipping stands that go in the spar holes on quick builds and they would be perfect. I would pay for shipping if anyone has some they aren't using for a while. I would be glad to return them or pass them on to someone else when finished.
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 09-05-2007, 08:30 AM
MTBehnke MTBehnke is offline
Here's what I did with a couple of 2x8's:
Fuselage stand
If you use inserts in the spar holes you'll have to remove them and use a different support when it's time to install the wings to drill the rear spar holes.
Mike Behnke
RV-9A - sold
