Originally Posted by Tbone
Has anyone sourced prices on the dynofocal 1 engine vibration mounts? I am getting ready to install the engine and was curious on quality and prices.
Van sells some low cost ones (VPI), but if you want the best get the Lord Corp J-9613-40's. They have better shutdown/startup movement control and in my opinion better quality overall. They do cost more, but if you Google you can find the normal suppliers: Spruce Aircraft, Sacramento Sky Ranch, Chief, WagAero. There are no discounts and prices vary from $100-$112. Just shop around. The best I found with a quick check was Sky Geek: $99.50
http://www.skygeek.com/engine-mount-mooney.html
Van does not sell *"Lord" dynafocal mounts; he sells a lowest bid third brand, VIP, not even Barry Controls.
Regardless if you get the "equivalent" to Lords J-9613-40 in another brand, like Berry
it will not be the same. Lord is the only one with a silicon filled damper around the spacer, which dampens large scale motion (see pic below). However in flight the silicone damper "de-couples" from normal vibration. Not a put down of Berry Controls, but they tried to copy this low motion design by just increasing the stiffness of the rubber. Thus people complain of vibration in flight with Berry mounts. Lord has the patent on this.
The down side Lord's go for about $100, Berry about $77 and what ever Van's cost, like $60 each. So you might pay about $160 more total? No big deal or savings if your fillings are rattling. Also less vibration during start and shut down means less cracked air boxes, baffles, oil coolers and fretting hoses & wires.
None of the other mounts have that silicon spacer/damper.
Typical spacer with out a damping spacer sleeve.
* Van does sell conical mounts for $99 each. I do believe these are "Lord" J-1552's, which are also awesome, for the conical engine. If you have a conical mounted engine, never use plan bushings, it's horrible set-up. Bushings may only cost $7.50 for each corner but you will not like it. It's a big bullet to spend $400 verses $30 in this case but its worth it. I had a RV-4 with conical mounts and it was NIGHT and DAY with the Lord mounts v bushings.
