Old 09-03-2007, 11:57 AM
prkaye prkaye is offline
Default firewall weldments - split?
Are these Powder-Coated wedlments on the corners of the firewall designed to split open along the edge, as in the photo here?
][/url]
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 09-03-2007, 12:04 PM
Mel's Avatar
Mel Mel is offline
Yes, they are designed to match up with the longerons.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 09-03-2007, 04:07 PM
AltonD's Avatar
AltonD AltonD is offline
That seem was not welded. It was just filled up with powder coat. I had the same reaction. Many other builders have had that as well.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 09-03-2007, 05:31 PM
N941WR's Avatar
N941WR N941WR is offline
What Mel said.
The front section of the longeron is twisted and comes down at an angle, thus if those things were welded out to the end, they would not fit the inside of the longeron. That is why they are not weled out to the end.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 09-04-2007, 12:27 PM
thallock thallock is offline
Default You found it, move on.
Contratulations, Phil, you have discovered the "Oh, No, the firewall weldements look like they are cracked" easter egg. Proceed to next step, and keep your eyes open for the next one. Van has planted quite a few of these for your enjoyment.
Tracy.
Tracy Hallock
Austin, Tx
RV-7(EH) - Fuselage
http://www.trv7.com
Old 09-05-2007, 07:37 AM
I got a good chuckle out of this... looking forward to those other easter eggs!
Phil
RV9A (SB)
Ottawa, Canada
