Old 09-03-2007, 10:40 AM
cbnank cbnank is offline
Default Oil Tempertature Sender
I have a Superior IO-360 engine. I am installing a brass oil temperature sender. There are no instructions to add a lock washer, crush washer and no holes to safty wire it.
I looked in the Superior OH & installation manual, no joy. Also did not find anything in the VAF search engine.
Does anyone know if I need to install as is or what is recommended for safty.
Thanks for your help.
Carl Nank
Western Kentucky
RV7A, firewall forward
Old 09-03-2007, 11:39 AM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Crush washer
Does anyone know if I need to install as is or what is recommended for safety.
This sensor probably belongs to the airframe, not the engine, so it's not in the Superior manual...
I checked my Tiger Parts Manual, and they use a SW brass sensor like you describe.
The only washer called out is a MS 35769-1 Crush Washer. They also call out safety wire (0.032), and the sensor hex nut portion is drilled for a safety wire. The engine case should have a safety wire hole nearby.
At the wire (electrical) end, it shows a plain washer, split locking washer and plain nut - no part numbers since I believe these parts come with the sensor.
Hope this helps.... gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
