From folks over the years trying to put OAT's in the side of body air vent NACA scoops has shown temps are almost always significantly many degrees higher than ambient (3-7 F). Also prop slip stream does play a part in flow and temp through the vents.
HOT? Not sure about hot, but what else could it be, engine heat. Seeing you are in Florida, it is summer. The only thing you can do is climb to cooler air.
The suggestion to reduce cowling seem leak sounds excellent.
Related to staying cool, consider some kind of sun shade / screen to suction cup on the canopy. If you want more air consider a third/forth vent, like those round or square pop out deals Van sells. It's still going to be hot, but you will have more circulation which may make you FEEL more comfortable. Back in school in HVAC class, the formula for comfort is Temp, Humidity and Circulation. You need all three, but with out A/C you can only increase circulation. More wind on the face will make you feel cooler.
