Old 09-01-2007, 09:07 PM
Yukon Yukon is offline
Banned
Default Canopy is Easy as Pie
Canopy is going well, getting ready for the rivets. Maya helped me drill the holes yesterday, ACS plexi drill did a great job. This canopy work has an undeserved bad reputation. Don't worry about it, just press on!!!!
Old 09-01-2007, 09:16 PM
rv9aviator rv9aviator is offline
First the boat, now this. You're killing us man!
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
Old 09-01-2007, 09:20 PM
Banned
Default Maya, my Maya!
Dude, what can I say??? She can cook too!
Old 09-02-2007, 05:41 AM
RV8N RV8N is offline
Just don't get too cocky. It will jump up and bite you when your not expecting it.
Patience Grasshopper.
Karl
RV-8 #80240 SOLD
1999 BMW R1100RS
Old 09-02-2007, 06:02 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default roger that houston
Karl
not to jinx but theres plenty of time left to crack it. it is easy but it cracks even without knowing it. seen it twice already. right drill right speed right pressure. several holes already drilled then tick? hmm,what was that,only to find a radiating crack later around a screw hole. it is an overated experience though. good luck. i thought the baffles were the worst part of the whole kit. the instructions are lame.
note:@75 deg. i tried to crack some scraps after being warned and used various drill bits...i couldnt initiate a crack with varying speeds and pressure but its only because the gods knew it was scrap. the back would chip out badly but thats it, and i crammed the drill through it. the two i know of cracking were light and gentle one was heard one was not.
William Weesner/ still kicking.
Old 09-02-2007, 10:06 AM
Banned
Taking it all in, I'm thinking that temperature must be the big variable. Everybody needs to know that it is hotter than the surface of the sun in my garage, here in Phoenix, Arizona. Never less than 90 degrees, sometimes 110.
The plexi drill feels like it is drilling into butter, never having a tendancy to bite or dig in. Be very careful if it is cold where you are!
Old 09-02-2007, 10:57 AM
DanH's Avatar
DanH DanH is offline
Pick up a 10X magnifier and look at the back side of your holes. Prepare to be afraid <g>
A hole-type single flute countersink/deburr tool (applied lightly) will smooth the edges of the holes. "Break all edges" is a plexiglass rule too.
Dan Horton
RV-8 SS
Barrett IO-390
Old 09-02-2007, 10:59 AM
cytoxin's Avatar
Default Phoenix
man when i watch the weather channel i always see the temps there and cringe.. isnt that always the case? 6 of one and a half dozen of the other.
the hottest its been in my shop all year is 107..but the humidity is the butt kicker. i had a puddle of water on my porch .250 deep stayed for days in the 90-100 heat.
Old 09-02-2007, 11:32 AM
AltonD's Avatar
AltonD AltonD is offline
yeah, yeah, yeah. Mine cracked on the very last hole.
Alton DeWeese
N526RV RV7A Tip Up, IO360 180 W/Hartzel BA prop.
Flying ~950 hours since Aug 2010
N4IDH
Construction Log
?The secret of getting ahead is getting started. The secret of getting started is breaking your complex overwhelming tasks into small manageable tasks, and then starting on the first one.?
?Mark Twain
Old 09-02-2007, 11:38 AM
Banned
What was the temperature? Were you drilling or riveting or "screwing"?
