Old 08-30-2007, 08:54 AM
dustman dustman is offline
Default Com antenna
I'm planning on using one of the simple cooper strip antenna the instructions say to basically stick it on the wind screen. I have an RV3 just sticking it to the windshield just doesn?t get it its going to be very visible and very much in the way any suggestion?
Old 08-30-2007, 09:41 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Dont. Put a whip on belly.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 08-30-2007, 10:11 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I agree with Mike - for your #1 (or only) Comm, put on a good, solid-performing whip. For secondaries, you can go with something a little less robust (I am using a wingtip antenna for my #2, and it has limited range, but only use it for formation, ATIS, or in the vicinity of airports).
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-30-2007, 11:06 AM
Default whip it is
thanks for the advice
