08-28-2007, 12:20 PM
Lycoming 0-360 manuals
Hey gang,
I'm looking for manuals for the ECI 0-360 kit I just purchased and I'm wondering if there are revisions to look for, etc. I contacted ECI, who said they don't currently have manuals, and that I should get the Lycoming manuals. There are a few listed on eBay, but I'm wondering if there are revisions or part numbers to be aware of.
Also, what manuals would you guys recommend I buy? Operator's manual? Overhaul manual? What else? Thanks for your help!
Sonny W
Boise, Idaho
RV-7A Flying!
08-28-2007, 12:42 PM
At minimum, O/H manual (same for all direct drive engines), and PC-306 parts catalog.
Radomir
RV-7A sold
08-28-2007, 01:00 PM
Manuals
Sonny,
Check your private messages.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
08-28-2007, 01:05 PM
Guest
Skip eBay
I made the mistake of buying one off of eBay, it was a "reprint", and when I got it, I think it was dated 1962. Made for a good bird cage liner. I bought the "official" overhaul and parts catalog from Lycoming, pricey but in my opinion well worth it, and they give you a couple of years of updates. Hope this helps.
08-28-2007, 02:28 PM
Radomir, Glenn, and Mark...thanks guys!
I think I have everything I need, with the exception of the Operator's Manual. I found it for $14 here: http://www.esscoaircraft.com/product_p/7022.htm
It's the 5th edition (1989)...there is a more recent edition in 1998. I think I'll hold off until someone tells me what they think.
Sonny W
Boise, Idaho
RV-7A Flying!
08-28-2007, 04:05 PM
Superior Vantage on-line...
Superior Engines has kindly put their Vantage Manuals on-line....
http://www.superiorengines.com/vantageManuals.asp
Since their certified Vantage is essentially a Lycoming clone made from PMA parts... the overhaul manual should do... and is much better written and clearer than the 2002 (but originally written in the 50's??) Lycoming one.
I would purchase a Lycoming parts manual though, since then you can reference both ECI and Superior part numbers using the A.E.R.O. web site.
http://www.aeroinstock.com/
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
08-29-2007, 09:35 AM
gil A
Thanks Gil,
I noticed that they have an Operator's Manual...do you think it would be the same as a Lycoming manual? I don't know if there is any variation in how these engines are designed/built...but I'm guessing if there were differences I would want to use the right manual.
Sonny W
Boise, Idaho
RV-7A Flying!
08-29-2007, 11:41 AM
Seem to be the same....
Originally Posted by lostpilot28
Thanks Gil,
The only difference I really see in the Operator's portion of the manual is the allowed use of 91 octane auto fuel... with some restrictions that are detailed.
The installation portion of manual is more detailed and well written, and even though it is a certified engine, it gos into definition of items that are usually the realm of the airframe manufacturer - such as motor mount part numbers - try finding that in the Lycoming documentation...  ... Probably as an aid to home builders.
Unlike ECI, who claims 185+ HP for their experimental O-360s, the Vantage series keeps the charts to a 180 HP max. Perhaps this is to keep the interchangeability for certified aircraft?
As an O-360 user in my Tiger, the checklists would seem to be usable for me... one interesting item that got assigned to the airframe manufacturer was the RPMs for a mag check.... use the "standard" 1800 rpm....
gil A
Gil Alexander
08-29-2007, 12:54 PM
Thanks again, Gil. By the way, noticed that you're in the Tucson area. My fiance is from there and we go down there occasionally to visit her family. If you don't mind visitors, I'd like to check out your RV sometime.
Sonny W
Boise, Idaho
RV-7A Flying!
08-29-2007, 03:30 PM
No problem
No problem... and if you fly in, we have free tie downs and cheap fuel for guests of residents... Prior Permission Required though....
I guess you'll wait until it cools down though...
gil A
Gil Alexander
