Old 08-27-2007, 07:14 PM
dustman dustman is offline
Default aileron up down angles of deflection
Ok I solved the puchrods rubbing situation and now im trying to set the travel on the ailerons. The manual said there was a template in the packing crate for setting the angles not im my crate. I have been trying to set the angles using a straight edge and a protractor. I think the idea is sound and if so i have 25 up and 18 down plans call for 30 up and 20 down. Any ideas on a more accurate way to go about doing this? RV3
Old 08-27-2007, 07:59 PM
Mel's Avatar
Mel Mel is offline
The template should have been drawn on the bottom of the top of the crate. You cut the template out of the crate top.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
gstone gstone is offline
Default angle finder!? I think that's the name....
These are little circular, bottom weighted pointers that have a 360' scale that the pointer indicates degrees of angle on. They usually have a magnet on the bottom. Find them at any tool store, just about!
Then you can measure how many degrees of deflection by comparing the two positions, easy!!
Greg
Old 08-27-2007, 08:46 PM
TerryWighs TerryWighs is offline
Maybe using a digital level secured on the aileron would make this task a little easier and more accurate???
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
