Old 08-26-2007, 01:02 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Default CS Prop Question
Today when I started my engine for its second time one of the things to do was cycle the prop. I could not get it to cycle. There was no change in oil pressure or rpm's. The cable is hooked up properly and the arm on the govenor goes through its full motion. It is an MT prop and govenor. The new engine was sent to me ready for a CS prop. I removed the plastic plug at the flywheel that was sealing off oil from coming out before mounting the prop. Any A&P's out there have any thoughts as to why?
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 08-26-2007, 01:23 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I'm not an A&P Mike, but.....you need to have at least 1800 RPM's to get the thing to cycle. (1790 won't do it....at least not for me).
I had the same concern after my first engine run - and man, 1800 RPM sitting static seems like an awful lot sitting in your newly minted bird!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 08-26-2007, 02:23 PM
N131RV N131RV is offline
Default Hmm
My prop will cycle at idle.
I have a woodward governor that came with my used engine and a Hartzell prop from Vans.
When I first started my engine, the prop would not cycle for quite a while, around 10 minutes. I suspect that oil had to circulate fully through the system, etc.
Now it works instantly.
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 08-26-2007, 07:54 PM
sf3543 sf3543 is offline
My Blended Airfoil prop and MT governor will not cycle unless there is at least 1800 RPM.
One caution, ECI's break in instructions for new engines caution not to cycle the prop until either 5 or 10 mintes into the first flight. Something to do with certain pressures that cycling the prop puts on the cylinders while the rings or seating or on the cam lobes...I used to know but forgot the reason they gave me.
Anyway, you might want to check that out.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 08-27-2007, 09:04 AM
drakerv drakerv is offline
Default prop
You will need to cycle the prop several times at first to bleed the air out of the lines. Try that. Marc
Old 08-27-2007, 10:55 AM
Bob Brown's Avatar
Bob Brown Bob Brown is offline
Mine also takes at least 1800 to cycle...I usually use 1900.
RV7A-QB, RV-10
Old 08-27-2007, 12:53 PM
erich weaver's Avatar
Yes, they do say say that, but who among us would hop in their just completed plane with a brand new engine and take off without cycling the prop first? I asked the tech at ECI if he would actually do this and he started backpedalling on just how important this requirement was. If anyone else has also had this conversation with ECI I would be interested in hearing about it.
erich
Old 08-27-2007, 02:24 PM
Jamie's Avatar
Jamie Jamie is offline
Erich:
What is the danger if the blue knob doesn't work in flight?
Old 08-27-2007, 02:28 PM
osxuser's Avatar
osxuser osxuser is offline
As long as the prop RPM doesn't run away at full throttle, i'd have to problem taking off without cycling the prop. Cycling only gives you limited information anyway, it doesn't really tell you that the prop/governor will govern or not.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 08-27-2007, 03:24 PM
I personally didn't have a problem with it, since the takeoff and landing setting should be the high RPM setting anyway. If you didn't feel comfortable cycling the prop in flight for the first time, you could always land, cycle it and then feel better for the next flight.
I followed ECI's instructions to the letter. No use giving them an out in the event that you had a warranty situation.
Steve Formhals
RV3B
RV8
