Push Rod Issue
I had the same problem on my 9A. They were touching the spar at about 15 degrees on the down angle. I called Vans, and they said no problem, just bore out the opening a bit with a grinder. I used a sanding bit on a Dremel. It worked just fine. Since then I have been looking at other planes when attending airshows. I have seen several with the same issue.
_____________
Peter McCoy
RV9A N35PM S/N:91335
First Flight: April 2013
Hobbs: 400 hours after Oshkosh 2017
www.myrv9.com
