VAF on Twitter:
@VansAirForceNet
Old 07-22-2022, 08:00 AM
egp8111 egp8111 is offline
Default canopy chip repair using rod
Hello All,
My new used RV6 has a chip on the inside of the canopy(looks like someone threw a clipboard or something on the glare shield) I've heard of a technique to drill out the chip then glue in a piece of plastic rod and polish out. Anyone have any experience with this ? I'm not finding much when I search.
Skip
NC
RV-4 loved and sold
RV-6 learning to love
Old 07-22-2022, 08:42 AM
CATPart CATPart is offline
I have no experience with this..but, I have worked with an acrylic supplier that could bond acrylic together and it was completely invisible when done. So I know what you propose can be done. Acrylic can be machined, sanded, and polished to look water clear, so repairs can be whittled into something you can live with. Although, a bad repair could be worse that the original problem or so I reckon.
A quick google brings up these solvent based bonding agents which are probably the way to go if chosen and used right. Shooting from the hip here a bit, sorry.
https://www.eplastics.com/accessorie...s/acrylic-glue
Old 07-22-2022, 09:13 AM
PaulvS's Avatar
PaulvS PaulvS is offline
Default Plastifix
Hi Skip,
There have been previous posts on VAF about using Plastifix to repair cracked canopies. I haven't personally used it but their results looked good.
https://www.polyvance.com/pfxcanopy.php-1
You may well find that the scratch will become less noticeable after you've owned the plane for a while...
Paul vS (yes I'm also a Van)
Building RV-6A #22320 O-320 FP. Wings and tail complete, fuselage almost done, working on canopy.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
Old 07-22-2022, 12:38 PM
clam clam is offline
Refer to AC 43.13-1B, para 3-24 and the PolyVance Plastifix kit.
I recently performed this repair, but have not yet gone through the polishing steps. I have a Micro-Mesh kit to use for the polishing. The 1/8" dia rod can be found easily via online search.
RV-8 N605TT
KFYE
