Old 08-23-2007, 08:28 PM
Bill Palmer Bill Palmer is offline
Talking Nose Gear Attachment Taper Pin
For those interested in purchasing the AN386-4-13 taper pin to mod their nose gear attachment per Jim Ellis' instructions (http://www.matronics.com/wiki/index.php/Nose_Gear_Strut):
I just finished working with Aircraft Spruce (West) to set-up a part number for ordering an individual AN386-4-13 taper pin. The new ACS part number is 04-01939. The price is $10.50. ACS has placed an initial stocking order with their supplier. If enough orders are received, ACS will continue to stock this particular taper pin and retain the individual part number 04-01939.
Bottom Line: No more special orders or minimum quantity.
Please place your AN386-4-13 order with Aircraft Spruce.
Best Regards,
Bill Palmer
Chino Hills, CA
P.S. ACS already stocks for individual order the other hardware listed by Jim Ellis as follows:
AN975-5 Taper Pin Washer, AN310-5 Castle Nut, and AN380-2-3 Cotter Pin. Personally, I substituted the slightly more expensive MS17825-5 Self-Locking Castle Nut for the AN310-5.
Old 08-23-2007, 09:01 PM
gasman gasman is offline
Might be best to do this on all socket landing gear..... That would be all of Vans kits. Less the 8 and 12...
And then check the torque of the nut at each inspection.
Old 08-24-2007, 04:48 AM
N131RV N131RV is offline
Default Which reamer?
Which part number for the reamer and does ACS sell that as well?
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 08-24-2007, 07:30 AM
Talking Taper Reamer
Joe,
The #3 Brown & Sharpe taper reamer is available from Aircraft Spruce: Part Number 12-09900, $44.95 plus shipping.
Best Regards,
Bill Palmer
Old 08-24-2007, 10:19 AM
Unhappy Backordered
Of course, the taper pin is a backorder.
Musta been too slow on the keyboard.
Joe Portman
Rebuilt as TD
Old 08-26-2007, 06:08 PM
Oldgeezer Oldgeezer is offline
Default Taper pin
Bill
Just ordered my parts from ACS. Taper pin back ordered, but thanks for doing the leg work.
Oldgeezer
RV9A
Old 08-27-2007, 12:59 PM
Talking Backorders Are Good!
Actually, backorders are good, since many backorders will convince Aircraft Spruce to stock the AN386-4-13 taper pins permanently and in bigger quantities. I'm also back-ordered! I'll let you know when the first batch of pins arrive from ACS's supplier.
Keep those taper pin orders coming!
Take Care!
Bill
Old 08-29-2007, 03:52 PM
Talking Taper Pins In Stock
I just received a call from Aircraft Spruce - - They have received their initial AN386-4-13 taper pin order from their supplier. At this point, ACS is ordering and stocking relatively small quantities, so the backorders will probably continue for awhile until Aircraft Spruce is comfortable with the demand and orders taper pins in larger quantities. Keep those taper pin orders coming!
Best Regards,
Bill Palmer
Old 08-30-2007, 02:38 PM
Jim Ellis's Avatar
Jim Ellis Jim Ellis is offline
Hi Mark,
I might be wrong (I usually am), but the taper pins shown on the McMaster-Carr catalog page you listed don't seem to have the correct dimensions for a Brown & Sharpe taper reamer. The Brown & Sharpe taper should be 1/2 inch per foot.
A #3 B&S taper reamer would have a small end that measures about .313" and a large end of around .375" if the flutes are 1.5 inches long.
I searched the McMaster site for a Brown & Sharpe taper reamer, but couldn't find any listed.
It would be worth a phone call to check for sure before you order.
Jim Ellis
RV-7A, N23VC, Slider, Garmin G3X Touch Panel,
Barrett Precision Engines Superior XPIO-360,
Dual P-Mags, Airflow Performance FM200A,
Classic Aero Designs Interior,
GLO Custom Aircraft Paint,
Flying
RV-9A N155T, Sold
Old 08-30-2007, 03:08 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default I believe you are right this time!
Originally Posted by Jim Ellis
Hi Mark,
Jim,
I was thinking the Brown & Sharpe was "just" a brand name. (which it is)
But they must have their own taper!
The ones in Mcmaster Carr are 1/4" per foot!
Good catch, I'll delete my post above before someone orders one!
I have not ordered it.
Thanks!
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
