Old 06-21-2022, 09:00 PM
WingnutWick's Avatar
WingnutWick WingnutWick is offline
Default Fuel level sender wire broken.
Been asked to fix a fuel sender wire coming from the tank that has a broken ring terminal connector. (see photo). I figured I could probably just rotate the flathead fitting there to unscrew it and replace the connector but when I do it just keeps spinning without coming out. Having no experience with these senders from a maintenance/build/install standpoint I am curious if I am going about this the correct way. Do I have to pull the entire plate off to be able to get to the other side to unscrew this? If so, how much of a pain is that?
Thanks all!
CW
Click image for larger version
ID:	27332  Click image for larger version
ID:	27333  Click image for larger version
-Wingnut
F-18E/F, Mk.58, CF-5
Own: RV-8 & RV-10
Old 06-21-2022, 09:59 PM
bruceh's Avatar
bruceh bruceh is offline
You'll need a new sender. Thankfully, they aren't expensive.
Inside is a wire that is soldered on to the screw base, and once the base loosens, then you will just spin the wire until it twists too much and snaps off.
You can verify that the wire has snapped off with an ohmmeter. Scrape off the sealant, then apply some PolyGone sealant remover to help remove it, scrub it clean with scotchbrite and some acetone, then get some tank sealant for putting the new sender in. I would also recommend using NAS1352-08-8P socket head screws instead of Phillips screws to install the new sender.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2022 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 06-22-2022, 08:06 AM
Sportquattro's Avatar
Sportquattro Sportquattro is offline
The use of cap head (Allen) screws is definitely a good shout, there is precious little room to work in and if you end up with a chewed crosshead screw it will be a swine to remove easily. Cap heads all the way
Nige
Nigel Heald
RV9a G-CSAM @ Exeter EGTE UK
Finally finished
Old 06-22-2022, 08:46 AM
Plummit's Avatar
Plummit Plummit is offline
Hmmm.... That sender looks familiar....
-Marc
RV-10
N814RV
2022 Donation Made
Plus extra donation for someone who didn't
Old 06-22-2022, 09:56 AM
HFS HFS is offline
Default What I Did - To Fix That
It's too bad the manufacturers make their sending unit with this "fatal" flaw. If you don't know about the possibility of the shaft rotating (and separating the soldered wire from it) before hand, you are almost guaranteed to go into the "no fly zone".
Knowing that ahead of time, this is what I did:
Removed the screw, and replaced it with an Allen screw (with a bit of red Loctite) - and then used the hex recess in it to hold the shaft in place when installing/removing the sending wire.
YMMV - But this does solve the problem.
HFS
Name:	Fuel Level Sender -Stud Mod.jpg
Old 06-22-2022, 01:51 PM
If this is a 4 or 6. Which it looks like, the tank is very easy to remove. Not counting draining, less than 10 minutes. For the later models, the Z brakets on the back of the tank are a bear. So, if older model, just drain and pull the tank. Dont bother working in that tight space.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
I donate every year on my B-Day (in Dec)
