Old 08-21-2007, 03:03 PM
cjensen's Avatar
cjensen cjensen is offline
Default Wing root fairing?
Rob Johnson and I were talking last night, and I brought up the wing root fairing. I'm to a point in the instructions to where it says to fit and drill them in place. I don't have them.
Do these come with the finish kit, or did I miss them in the inventory for the fuselage kit?
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 08-21-2007, 03:10 PM
Brantel's Avatar
Brantel Brantel is offline
Chad,
Pretty sure they come in the finish kit because I did not get them either. I do know that they can be fitted much later in the game....
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 08-21-2007, 03:22 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default Finish kit
Yep, in the finish kit.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 08-21-2007, 04:07 PM
rvtach rvtach is offline
Default They are in the finish kit.
Instructions with one kit; parts with another. Go figure.
Old 08-21-2007, 07:07 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Just don't bolt your wings on permanently, like I did, because you need to install a bunch of nut plates top & bottom.
On my 6A, there isn't much more than an inch between the fuse & wing, aft of the spar .
So today; three years after they were originally all bolted and torqued, I'm completing the process again; but painted this time.
L.Adamson Rv6A
Old 08-21-2007, 09:06 PM
robjohnson's Avatar
robjohnson robjohnson is offline
Hey Chad,
I just thought about this tonight while driving -- you can order those fairings ahead of time. I ordered a replacement fairing from Van's because I got over zealous with that edge rolling tool (I figured out how to fit it without edge rolling after I mangled the edge). Anyway, I ordered a new one from Van's and it rolls up nicely for shipping.
Just a thought...this would allow you to fit them now and not have to worry about it later on. You could also delete them from your finish kit when you order it.
Rob Johnson
Bloomington, IL
RV-7 N826RC - sold
1945 Piper J3 Cub - sold
RV-10 - wings with fuselage ordered
https://www.rv-builder.com
Old 08-21-2007, 09:13 PM
cjensen's Avatar
Good thinkin' Rob! I'll order a set tomorrow...Thanks all!
Chad Jensen
Old 08-29-2007, 08:17 PM
cjensen's Avatar
I got one (not TWO!) of my wing root fairings today from Van's. Are these not pre-punched normally?
I have two issues that I'm trying to work thru. First, there are no holes, so locating the holes underneath will take some measuring and marking. Not a big deal, but a pain nonetheless. I've read a couple of websites, and it sounds like they should be pre-punched.
Second...the fit is TERRIBLE! I have over a 1/2" gap between the fairing and the fuselage all the way around the fuel tank if I fit it for proper edge distance for the screw holes. The max gap according to the plans is 1/4", min 3/16".
I can't afford the $430 Fairings Etc. glass fairings, so I am going to have to make these work somehow...
Any ideas? Am I missing something here?
Chad Jensen
Old 08-29-2007, 08:29 PM
KirkGrovesRV8 KirkGrovesRV8 is offline
Sounds like something is fishy, my were prepunched and fit very well.
All the Best ;-)
RV-8
RV-9 once the kids are older
Old 08-29-2007, 10:22 PM
briand's Avatar
briand briand is offline
Read Dans write-up.
http://www.rvproject.com/20030105.html
My 8 had them with the fuse kit.
