Keep VAF
Going
06-20-2022, 03:00 PM
Torque for oil cooler lines
Does anyone know the recommended torque for the 3/8 npt inlets to an oil cooler?
Lancair 235/340
RV-9A (2013 - 2016)
06-21-2022, 06:45 AM
Refer to the builders construction manual. Because some of the fittings have a specific 'clocking', an actual torque isnt achieveble. So, generally, snug then 1.5 to 2 turns more WITH THREAD SEALANT, being aware of any necessary clocking.
Tom
RV7A Tail Kit Completed, Fuse started-Pay as I go Plan, on hold while we develop new products for RV builders
Ridgeland, SC
06-22-2022, 05:02 AM
1 to 2 flats, not 1 to 2 rotations, yes?
Dennis Callaghan (X26)
- RV14 sn:140193 - Awesome airplane!
- donation 11/27/2021 * 2
06-22-2022, 05:56 AM
Dennis--1-2 flats is for AN nuts---the op was referring to NPT threaded fittings, so 1.5-2 Rotations after lightly snug.
Tom
Ridgeland, SC
06-22-2022, 08:49 AM
Fitting torque
This comes up occasionally. Could someone put all the info into one thread and make it a sticky.
This thread is NPT fittings. Consensus seems to be 1.5-2 turns past lightly snug taking clocking into account.
Then there's flare fittings. Aluminum to aluminum, aluminum to steel, steel to aluminum, steel to steel, staninless to aluminum, stainless to steel, yada, yada. What are the torque values or is it flats? What radio station should be on? Rock, Country, Jazz, Blues? Seriously. One thread with some common sense postings or tables that are easy to understand would be greatly appreciated. Military Spec seem to enjoy confusion. Look at what they did to AN part numbers.
Heck, I would be happy to compile something to a spreadsheet if I had the data. Tabs for each material maybe.
Common folks. Lets help each other. Isn't that why we do this crazy thing?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
06-22-2022, 09:15 AM
Van's gives the instructions for NPT installations as Wirejock describes above in Section 5. Specifically 5.27 Fluid Fittings.
https://www.vansaircraft.com/service...d-revisions/5/
For the flared aluminum fitting torque values or the alternative tightening method Van's links to Aeroquip's technical data shown below.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
06-22-2022, 10:06 AM
Bulletin JA14A
Interesting. I see references all over the place to Bulletin JA14A but cannot locate the document.
Larry Larson
Estes Park, CO
Disclaimer
06-22-2022, 11:18 AM
AN Torque table
I found this table. Correct?
Larry Larson
Estes Park, CO
Disclaimer
06-22-2022, 11:27 AM
Torque table
I found a table for AN fittings. Is this correct?
Larry Larson
Estes Park, CO
Disclaimer
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
