Old 08-21-2007, 09:31 AM
SvingenB SvingenB is offline
Default Min size of compressor
I wonder what the minimal size of a compressor for the air rivet tool must be. Will 50 liters be enough (with 2-3 hp)? or too much? It seems that all larger compressors have 3 phase motors, and that will need a rewiring in my house, and i don't want that.
RV-4 #4520, Slow built
B Svingen
RV-4 Project Log
Onex Project Log
EAA Chapter 573 Norway
Old 08-21-2007, 10:15 AM
664781 664781 is offline
I built my whole airplane with a 2.5 hp with a 30 gal. tank. The samller the hp the bigger the tank needs to be.
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 08-21-2007, 10:36 AM
N941WR's Avatar
N941WR N941WR is offline
A friend has built his entire RV-10 with a small 4 Gallon Electric Hand Carry Compressor like this one from DeWalt.
He did use cordless drills for all the drilling but that little compressor worked great for riveting.
That said, I used a 5 HP belt drive, two cylinder, 35 gallon, 110 V compressor. The only downside of that thing is it is a bit small for painting.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 08-21-2007, 10:46 AM
Jeff R's Avatar
Jeff R Jeff R is offline
I have been using a small compressor, too, and it has been ok. It runs a lot when I use the air drill, but it has been able to keep up. It is a bit loud, and I had thought of buying a new, larger compressor, but since the little guy keeps up, I guess I will keep using it. But, if you don't already have a compressor, you may as well invest in a good one.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
Old 08-21-2007, 10:47 AM
DaX's Avatar
DaX DaX is offline
Standard Cubic Feet per Minute (SCFM) is really what you should be looking for in a compressor.
I looked for one with greater than 10 SCFM @ 90 psi that was 220V, no rewiring required.
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 08-21-2007, 11:30 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default do you want to paint it also?
if so you will likely want a 5 hp with a 60-80 gallon tank. i have painted cars with a 3 hp 20 gallon tank but it runs the compressor ragged. any will work for riveting and drilling. but the smaller ones have a rough time with air tools you may find yourself using on cars. yes they will run them but not very well.
this one is similar to mine. http://www.devap.com/products/view.asp?i=E7540
the direct drive oiless compressors are short lived units in the industrial world.
not to mention noisy as ****.
i know mine is a touch overkill but more is better for the work i do.
minimum for me would be 3 hp 20 gallon tank 120 volt.
William Weesner/ still kicking.
Old 08-21-2007, 03:49 PM
Mel's Avatar
Mel Mel is offline
Default DON'T USE HP RATINGS!
They are false and misleading. 5 hp on 110volts? I don't think so. Do the math. You might get 1 hp out of 110v. I haven't done the calculations for a while, but as I remember 1 hp equals about 15 amps at 110 volts.
Look for CFM ratings. My compressor is 5 hp, 18 cfm at 175 psi.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 08-21-2007, 07:18 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
My 60 Gal. compressor is one of those standups from Lowes. 3.5 running HP on single phase 240V.
Says 7 HP peak on the label.
10.8 SCRM at 90psi
12.2 SCRM at 40psi.
I originally completed almost the entire plane with a smaller 30 gallon, that said 3 HP, although that is probably mis-leading as noted in other replies.
The newer 60 gallon was for painting, and did just fine. Works a lot better for tools such as die-grinders too!
Home Depot also has plenty of compressors that compare with the size of mine, or larger.
L.Adamson
Old 08-22-2007, 09:52 AM
Ok, thanks.
I ended up with a 280 sl/min (@ 10 bar), 2 KW belt drive unit. I have no plans doing the painting myself. It should be enough for a rivet gun and other tools.
B Svingen
RV-4 Project Log
Onex Project Log
Old 08-22-2007, 11:00 AM
jcmcdowell jcmcdowell is offline
Default QUIET!
Excepting painting-
you can use a pretty small single tank portable compressor like those used on residential construction sites (air guns).
BUT-
get a larger belt drive- they are SOOOO much quieter and you will be spending A LOT of time in the shop.
It also helps because it's hard to hear your bucking partner (like for wings and fuse) with a loud compressor.
and what about all the great music you'll be missing...
jcmcdowell-
sold my RV9a kit
bought a flying RV7 taildragger
sold my RV7
I am a flightless bird!
VAF #976
